Re: Sparcomīs Drive95 Message #2 Posted by Raymond Del Tondo on 27 Sept 2003, 7:54 p.m., in response to message #1 by Thomas Otterbein
I don't use a 49GX, I think you mean the 49G+ ;-)
However, the Drive95 acts as a KERMIT server,
so if your 49Ganything has KERMIT,
it'll work. Just use the appriorate KERMIT commands.
Please note that the Filer library from the Drive95 diskette won't work in any 49G machine. That filer from James Donnelly is exclusively for the real HP-48 series.
For DOS based machines, like the LX series, a driver is supplied on the disk, too.
The HP-48 series and the 49G have a 'normal' serial port,
the 49G+ has a mini USB, maybe a usb-to-serial adapter could do, but that should be in the manual;-)
BTW: Watch the NiCd cells!
Raymond
