Re: Hp 38S II vs. 48GX Message #8 Posted by bill platt on 25 Sept 2003, 10:43 a.m., in response to message #1 by Cora Stewart
Hi Cora,
Well, here is another approach: you can run an emulator of the hp41c (or cv or cx) on your 48gx. I have been doing this for about 2 weeks, and it is really pretty neat. The 41 series is closer to the 32sii--it uses GTO and is RPN not RPL. For the "Input" command, you insted use the PROMPT command followed by STO xx where xx is a storage register. The registers are numbered instead of lettered, though the first 10 registers are implicitly lettered. I like the "Input" command of the 32sii though, as it is such a fast streamlined way to go, but if you put PROMPT on a user key on the 41c, you can code an input pretty fast (less typing).
If however you happen to use equations within your programs on the 32sii, that does not translate well to the 41c--you have to put the equation into a subroutine in RPN (using horner's method or other if need be).
The long of the short of it is that there is no easy way!
But some RPN programs translate very easily to RPL--skipping hte 41c emulator approach. I'll post some of the ones I have done, in a later post.
Bill
