PDF docs for 82240 Message #5 Posted by Randy Sloyer on 21 Sept 2003, 8:57 a.m., in response to message #1 by andrew
No cracking necessary.
HP placed this information in the public domain so that other OEMs could use the 82240. The technical specs exist as a PDF document:
http://www.hpcalc.org/details.php?id=4742
IIRC, the 42S does an initial preamble that is not documented in the spec. It seems to be 3/4 of a word, ~90us on/~550us off, 16 reps. I think it must be used to clear the input buffer of the 82240.
Edited: 21 Sept 2003, 9:06 a.m.
