Re: Does HP-42X work on the new HP-49G+? Message #3 Posted by Douglas Rohm on 18 Sept 2003, 8:38 p.m., in response to message #1 by Erik Ehrling (Sweden)
Hi Erik,
Here is my reply to your post in comp.sys.hp48.
(First reply)
Hi Erik,
I just downloaded it and it seems to be running okay. I haven't done any thorough testing yet, but I haven't seen any major issues. The header on the 49G+ remains at the top at all times, as usual. The HP42X screen fits nicely underneath this header so there aren't any display issues.
I did, however, notice that when you exit the emulator with !BYE or ON-F6, the screen clouds up for a second and then clears up and returns to the stack. Nothing is lost or corrupted in the emulator or the 49G+, but it isn't pretty to watch.
I'll let you know if I find anything else.
Doug
(Second reply)
The version I tested in my previous post was the HP42X49E version. I just tried it with the extended version and it doesn't work. I downloaded the HP42X file to the 49G+, stored it in port 1, where it showed up fine, then
did ON-C, then recieved the XQ42 file. Tried to run the emulator and the emulator screen shows for a fraction of a second, then the calculator turns off. I turned the calculator back on and I got "Error: Object Not in Port".
I checked port 1 and it was deleted either by the emulator or the calculator (I'm guessing the calculator).
It might be wishful thinking, but it seems like the 49G+ handles critical errors more elegantly, instead of "Memory Clear" messages. I'll prove this point more when I start doing more programming :)
Doug
