HP48 keyboard woes Message #6 Posted by Randy Sloyer on 18 Sept 2003, 8:56 p.m., in response to message #5 by Randy East
The ON button is normally lower than the rest. U can try this:
Place the unit on the desk in front of you. With a left finger, press down on the raised portion of the bezel above the B and C keys. Now with your right, try turning the unit on. You may find some pressure applied to the area described will get the unit working normally again. It may continue to work okay for a while or work only with pressure applied. If this test restores operation, the problem is an intermittent keyboard connection and can be repaired.
Post again if this works and we can go to the next step.
