Re: HP 11C Calculator Message #2 Posted by Victor Koechli on 15 Sept 2003, 4:58 p.m., in response to message #1 by Phyllis
Congratulations on your aquisition!
To change the display format, press [f], then either [Fix] for fixed decimals, [Sci] for scientific, or [Eng] for Engineering, then the desired number of decimals (e.g. [f] [Fix] 2 to change to 2 decimals fixed mode).
If you need a manual, get the Museum CD Rom available from this site, then start buying the calcs to fit the manuals you find there ;-)
Cheers, Victor
