HP-38C aand HP-97 Message #1 Posted by Jerry Pfile on 14 Sept 2003, 10:36 p.m.
Apologies for breaking in but I need some information.
I have the above to HPs but each needs a little work. Bought both new years ago but as I'm retired I have no professional need as I did then. However, I'd like to get them up and running for sentimental reasons if nothing else.
The 38C charger has disappeared somewhere over the years as has the box, manual etc. What was the charger model number? All I recall is that it had the two flat contacts housed in the male end of the AC adaptor.
The 97 has perhaps a fatal condition. The battery was removed years ago and lost. What model was the battery and are they still available? More ominous is that the "+" key has no "spring action" at all. Can that be repaired, or are replacement circuit boards still available in the aftermarket?
Would greatly appreciate any info someone can give me regarding the above.
Thanks in advance,
Jerry
