Zapping NiCd cells Message #1 Posted by Renato on 8 Sept 2003, 4:24 p.m.
I tried an alternative for zapping battery cells. I used a current/voltage controlled DC supply, instead of a large capacitor. Without any connection to the DC output, I set a 20V voltage limit, with a low current (300mA) limit. After the output voltage is stabilized, I connect positive output to cell +ve, and negative to cell -ve : ZAPPP.
So far so good, and much less clutter than using a capacitor.
