Re: hp 48s calc with 48sx manual (vol 1) Message #2 Posted by christof (NoVA US) on 3 Sept 2003, 4:12 p.m., in response to message #1 by Neil
The 48S and 48SX are the same aside from the external port expansion slots. So the manuals work for both- My 48S (also bught used) came with the later one big volume edition of the 48SX manual, which works fine. AFAIK, HP never put out a seperate manual set for the 48S as they did with the G series, HP put out one manual set for the 48g, 48g+, and 48GX)
I do prefer the printing where they had the manual split into 2 volumes, since they are wire bound and lay flat more easily.
But- you either have the one BIG single volume, in which case you ust need to dig deeper and find that everything really is in there, or you have the 1st volume of the 2 volume printing (again, they had the SAME information, just different printings), In which case yoou need to buy the MoHPC DVD/CD set with the 48s/sx manuals on it :)
and , incidentally, hpcalc.org has a great tutorial on user rpl. area48 has tons of information of all sorts that you will find very useful.
