Re: HP 9114B Battery Problems ??? Message #3 Posted by Victor on 3 Sept 2003, 12:57 p.m., in response to message #1 by Chris Catotti (Florida)
I was able to get a lead-acid 6V lantern battery from Radio Shack and was able to use it. I removed the existing battery from the battery pack, attached wires to the connections to the original battery pack via alligator clips, ran the wires out of the battery pack, and attached the wires to the 6V lantern battery. I was able to plug in the charger to recharge the battery, then use the drive normally.
I would imaging attaching wires to a normal 6V lantern battery would work OK as long as you didn't try to recharge it.
