Re: Port X-Tender Message #4 Posted by Chris(FLA) on 2 Sept 2003, 9:55 a.m., in response to message #1 by Kin Kaide Deveraux, New Orleans
I have 2 of these. I used to have 3 but sold one.
They are great if you have a 41C. I can load up my 41C with Quad, Time, Cardreader then plug the X-tender into port 3 then I can add IL, Ext-Func. and 2 X-Mem, Ext I/O, wand and either PPC or games ROM(They conflict). I can switch between the modules quickly with the dip switches.
They also have a battery so when you unplug it from the calc it will hold your memory information.
I opened mine to change the battaries and noticed that they aren't that complicated. I'm sure somebody could make one easily. The only problem would be the case that holds it.
Anyway great item to have if you have a 41C and more modules than available slots.
Chris
