Some facts to consider Message #4 Posted by Vieira, Luiz C. (Brazil) on 28 Aug 2003, 8:17 p.m., in response to message #1 by Charles Miller
Hi, folks;
I want to point out some facts and risk my own conclusions sbout this.
There is a warning in the HP48G manual about sysRPL programs written for the HP48S-series. Some internal calls were changed from S- to G-series, and some programs may generate wrong answers or disrupt the system operation, mostly the ones using these internal features. And I believe the Equation Library card will use them.
I'd also consider the fact that if the Equation Library is already part of the HP48G internals and both Tetris and Periodic Table are available as download files for the HP48G, than I'd keep the card with the HP48SX and load the 48G with the available files so both calculators will show about the same resources. If you use the card with the 48G, the Equation Library will probably conflict with the existing Equation Lirary in the HP48G and you'll not be able to use it. And you cannot load Tetris and the Periodic Table in the HP48S because there are some resources available in the HP48G that are not available in the HP48SX, and they are probably used by these programs.
My 2¢.
