Re: HP 41 rubber feet Message #8 Posted by Randy Sloyer on 27 Aug 2003, 12:13 p.m., in response to message #7 by Katie
I'm into preserving perfection :^)
I have found a good way to hide the white. First, clean the rubber sheet, and apply the tape so you can cut both the foot and tape in the same operation. I then cut with a rotary wheel cutter on a resilient cutting pad using a small metal T-square. It makes for very smooth, straight sided cuts. Almost as good as...
