97S Test connector outlay Message #1 Posted by Erik Wahlin on 2 Aug 2003, 4:49 p.m.
I had a few requests to map out my HP-97S test connector. It is a fairly simple thing to build if you can find the IC. Please see http://g.msn.com/9SE/1?http://www.emar-online.com/15xyzx.htm&&DI=293&IG=1d9138f3-ba80-4ad8-a0f6-4de9754a962b&POS=1&CM=WU&CE=1). This company may have some. Please see http://www.colutron.com/97S/97S.htm for the connector details, and http://www.colutron.com/97S/97S2.htm for the diagnostic program used with the connector. I have attempted as best as I can to double and triple check the connections. Please use at your own risk. I assume no liability if you damage your HP-97S.
Edited: 2 Aug 2003, 5:22 p.m.
