Re: Two questions on 41cx programming Message #3 Posted by Axel Poqué on 19 July 2003, 3:22 p.m., in response to message #1 by Sean McNamee
Finding a program is simple:
Enter CATALOG 1 (shift ENTER 1), and immediately press R/S. This puts you in the program catalog. Now you can step through the catalog using SST/BST. Programs without labels are identified via their end statement (eg. "END 18"). If you found the program you wanted, press <-. Now you can execute the program by pressing R/S, edit it in PRGM mode, or delete it with CLP (press XEQ ALPHA CLP ALPHA to exeute CLP, then ALPHA ALPHA, since CLP clears the current program if you don't supply a label).
For information on ROMs you could try ordering the MoHPC CD set, it has probably more manuals than you'd ever need
Axel
