Re: Blank-Nut On eBay? Message #2 Posted by Randy Sloyer on 15 July 2003, 10:47 p.m., in response to message #1 by Mark Hardman (LED)
For my 2˘ worth, the "clear tape on the bottom and sides" is probably holding the unit together. Once the top posts crack off, it's the standard user method to keep the battery/port connector in contact with the logic board.
In short, unless you are willing to solvent weld it back together, caveat emptor. That is of course if you are fortunate enough to get all the pieces. I doubt it though, as it missing a rear cover, so the broken bits had an escape port :^)
Or, being positive, it could just be holding the battery charger port cover on...
Edited: 15 July 2003, 11:06 p.m.
