Re: HP-34C CPU id number Message #4 Posted by Vieira, Luiz C. (Brazil) on 5 July 2003, 11:52 p.m., in response to message #3 by Jon
Hi, Jon;
thank you again. It seems the HP33E you mentioned in previous post has a paper label or a CPU code that's different of those I saw so far. As you mentioned you had some glue in the HP34C's CPU chip, it probably had a paper label on it, tto.
BTW, is this HP34C the one that had a [ Pr Error ] problem? Did you read my post about it? If so, did you succeed repairing it by changing the position of the chips (1) and (2)? I'm just curious about it, because if you did not get positive results, you may also have a power supply board with some sort of problem.
Best regards.
Luiz (Brazil)
Edited: 6 July 2003, 12:09 a.m.
