Re: HP 28C undo Message #2 Posted by Ernie Malaga on 26 June 2003, 5:11 p.m., in response to message #1 by Ted Hill
Ted:
Press the red shift key, then [MODE] (it's right next to the red key). Then press [NEXT]. You'll see the menu change. The fifth of the top keys is labeled +UND. If you press it, UNDO will be activated.
-Ernie
