Re: HP55 Message #4 Posted by David Ramsey on 20 June 2003, 7:45 p.m., in response to message #1 by Howard
The HP-55 has 50 programming steps, numbered 00-49.
With the program switch set to "Run", pressing GTO xx where xx is a two digit number between 00 and 49 will set the program counter to that number.
If you press GTO 23, then move the switch to PRGM, the display will read:
23. -00
The "-" is the 55's shorthand way of representing "go to". Thus, when there's no program in the calculator, every step is "GTO 00", represented as "-00".
All GTO addresses must be two digits. If you try to enter an illegal line number, i.e. GTO 56, the GTO will be ignored and the two digits will be entered by themselves. In this case "5" and "6" would be entered as separate steps.
Try this:
1. Turn calc off, then on.
2. Move switch to PRGM.
3. Press these keys: ENTER, 2, /, 5, 2, 8, 0, X, R/S
4. Move the switch back to RUN. Press GTO 00.
5. Enter "23" and press "R/S". The display should flicker and show "60720".
I suspect your calc works fine. Have you used any of the older keystroke programmable HPs before?
