Re: Woodstock Slide Switchs Message #2 Posted by hans brueggemann [ger] on 6 June 2003, 11:25 a.m., in response to message #1 by Trent Moseley
trent,
the lubricant deposit in and around the switches is normally sufficient for a lifetime. the switches must not be 'oiled', but 'greased'. mineral oils may 'brittle'or deteriorate the plastics over time. teflon grease especially made for plastic parts worked fine for my -67.
it is always a good idea to remove the residues of old lubricants completely before applying new lubricants, just in order to prevent mixing (with unpredictable long time results) of different blends.
cheers, hans
