Always welcome, Nenad! Message #13 Posted by Vieira, Luiz C. (Brazil) on 15 June 2003, 1:58 a.m., in response to message #12 by Nenad (Croatia)
Hi, Nenad;
these babes have their secrets... Sometimes it is a good surprise knwing something new, ahn? Anyway, did you get the meaning of the "C" in the HP12C? This feature was not available in the HP38C/E.
You know something I also noticed in the HP38C/E? If I am not wrong, it was the first HP programmable calculator to offer PRGM/RUN mode selection by toggle key, too, instead of a sliding switch. Even the HP34C has a PRGM/RUN switch. Advantage? It alwys switch to ON in run mode. All RPN programmable LCD's have a toggle key are like this, but some of the new ones (after Pioneers) switch back to ON in the same state they were when switched to OFF (I know you know that; just illustrating :).
Best regards, my friend. Be well.
Luiz C. Vieira - Brazil
Edited: 15 June 2003, 2:05 a.m.
