Re: HP 42S & 82240B Printing Test? Message #4 Posted by Randy Sloyer on 30 May 2003, 1:11 p.m., in response to message #1 by Gregg
Self test the printer:
With the power off, press and hold the form-feed button on the right side. Turn on the power and now release the form-feed button. The unit will self-test and print a character map and the battery level. 5 is the highest. Replace the batteries if you are 2 or below.
On the 42S, press:
- Shift,- (print}. Press the scroll down arrow 2 times.
- The menu should read PON POFF MAN NORM TRACE.
- Press the E+ key to activate PON (printer on).
- Press LOG to set MAN mode.
- You should now be back to a normal screen.
- Press shift,- to access the print menu.
- Press the LOG key to print the stack contents or any of the other menu picks there to do whatever you want.
As Richard mentioned, don't forget to disable printing when not needed, especially when in trace mode.
Repost if you help more...
