Re: HP41CV Help/Advice Message #2 Posted by Vieira, Luiz C. (Brazil) on 28 May 2003, 1:33 a.m., in response to message #1 by Steve Gosselin
Hi, Steve;
let's first identify which model you have. Please, look at the LCD window and compare what you see to the image below.
This image belongs to the HP Museum (this site).
In both cases, the best starting point is cleaning batteries contacts, the ones in the calculator. If you see they are O.K, chances are you have a small battery leakage and that the residal leak got between the kayboard and the battery connectors assembly. In this case, it's necessary to open the calcualtor. Do you need advice for this?
If so, let us know so we can continue.
Best regards.
Luiz C. Vieir - Brazil
