Re: Help needed - Woodstock external battery charger Message #2 Posted by Tony Duell (UK) on 27 May 2003, 5:04 p.m., in response to message #1 by Renato
It's glued together :-(. The main area for glue is between the flat part at the bottom of the battery cavity and the bottom part of the case.
You have to carefully prise (pry) it apart. Once the 2 parts of the case have separated (hopefully without too much damage -- mine came apart cleanly), it's easy to extract the little PCB. The circuit is really simple -- 2 resistors, a diode, and the LED.
