Re: Key Click Message #2 Posted by David Smith on 18 May 2003, 9:14 p.m., in response to message #1 by Howard
MOst likely your HP65 key strips have developed vertical splits on the left hand side of each place whre the strip rises up into the key "dome" contact. Onlt fix is VERY drastic and not at all easy to pull off properly. You must find another machine with good click (an HP35 or 45 will do), slice the key strips off the keyboards, and transplant the good ones onto the HP65 keyboard. The old strips were spot welded in place. You need to solder the new ones down.
