Re: 9114A vs 9114B disk drive Message #4 Posted by Diego Diaz on 17 May 2003, 12:08 p.m., in response to message #1 by Jon
There are also differences regarding the power supply and the battery charge gauge.
9114A uses 88014A battery pack with a very simple charging circuit.
9114B uses 88014B wich includes a more alaborated circuitry.
Anyhow you can swap them as they both have the same physical dimensions and the same connector.
9114A has one only led to display battery/power status, while 9114B has a three led gauge to tell the users the "amount" of charge still remainig in their batteries.
Also the drives are different, both mechanical and electrically.
Cheers.
