Re: HP 41 battery/port connector Message #1 Posted by David Smith on 14 May 2003, 4:25 p.m.
Actually, I use brass "U" channel from hobby shops. It is much heavier than foil, much easier to find, and should last a life time.
The battery contact assemblies are all interchangeable. I have seen revision numbers A-E, but they are all compatible.
