Re: HP-97 Charger Spec Message #3 Posted by Vieira, Luiz C. (Brazil) on 11 May 2003, 1:47 p.m., in response to message #2 by David Ramsey
Hi;
there are at least six HP AC adapters compatible with HP97's original. All topcats (HP9x) may use them, also the original HP41 peripheral printer 82143A and some HPIL devices, like the 82161A (tape drive) and 82162A (thermal printer). All of these "guys" are powered by the same battery pack, too.
The three AC adapters I own that can be used with these equipments are:
82059B 82066B 82040B
all of them have the same output connector and they are rated:
8 VAC 3VA ow 3W(82059B
I think the HP97 input specs are for mean average AC input voltage while 8VAC is the AC adapter voltage itself. As I have no HP97 (at least so far), I cannot go any further about the calculator specs.
Hope this helps a bit.
Luiz C. Vieira - Brazil
