Re: matrix ROM fro the 9825 Message #3 Posted by Ellis Easley on 3 May 2003, 4:56 a.m., in response to message #2 by Katie Wasserman
The 9825B comes with most of the standard ROMs inside, there are jumper options to select between two different plotter ROMs and to trade off ROM space for extra RAM.
These ROMs are built in: String Variables, Advanced Programming, 9862A and 9872A Plotters, General I/O and Extended I/O. Matrix, Disk, and Systems Programming ROMs can be used with either 9825A or B. There are two different Disk ROMs, one can be used only in a 9825T. The Systems Programming ROM comes as a plug in cartridge for use in the 9825A; for the 9825B it is part of the internal large memory option that turns a 9825B into a 9825T. [That sounds like the Systems Programming ROM replaces the OS ROM on the right side of the 9825A, which the 9825B doesn't need since the ROMs are in the card cage.] This is from "HP 9825 Desktop Computer Operating and Programming Reference", 09825-90200 November 1980. It covers both A and B.
