Re: how do i remove the 71b bezil? Message #2 Posted by David Smith on 28 Apr 2003, 5:54 p.m., in response to message #1 by db(martinez,california)
Although I have not done this with a '71, it does work on the 11C, 15C, etc. Also , dont think that removing the bezel will let you easily remove the display window... it is bonded to the case, not the bezel.
First find a product called UnDu at your local hardware or office supply store. It is the solvent heptane and causes any adhesive to forget about sticking for a few seconds. Next soak a strong thread in it and place a couple drops of the solvent under the bezel. Use the thread like a cheese cutter to slice through the stickum. Keep it wet. Also try and keep the solvent off of the keyboard background as it may leave some watermarks behind.
