Re: HP9100B Repair Message #2 Posted by Ellis Easley on 18 Apr 2003, 10:27 a.m., in response to message #1 by Thomas Falk
Mine developed an intermittent display at one time. I was able to trace the problem to a transistor on the vertically oriented board on the far right side of the base (not one of the main plug-in boards with ejectors in the card cage). The schematics show a connection directly from the power transformer to the logic - or possibly limited by a resistor in the power supply chassis. The transistor that failed simply squares up the AC signal from the transformer and the squared output signal is what starts every re-paint of the display. The squaring circuit is a common emitter amplifier overdriven by the AC input. The transistor was shorted from collector to emitter by the time I found it.
I don't remember exactly what pointed me in that direction or where I heard that the display was synchronized to the line the way it is - possibly it's in the text in the manual? Here you go - on the power supply schematic, it starts at pin 6 of the transformer and goes to 2K resistor "R1" and from there the signal is labeled "60 Hz sync to display J27-K". That's pretty clear! BTW, be careful counting pins on the connectors that use letters to identify the pins - some letters are skipped to avoid ambiguity.
The machine had worked fine when I first acquired it and then it was in storage for a number of years. I had just "torn it down" to clean everything and then put it back together and it was working fine. I left it running and went out of the house for a while. When I came back the display was dark and the unit was very warm. I had left it sitting on a sheet of foam that I had used for protection while I was working on it, and had blocked all the air inlets in the base. I turned it off, opened the case and went away to pray for some time. After it cooled off it worked OK but then I found that the display would go blank intermittently and seemed to respond to tapping the case (you've got to try that!).
I think I followed the AC signal just because it was something simple that went down into the logic and luckily, found the incorrect behavior of the shorted transistor right away. I replaced the transistor with a 2N3904 or 3906, I don't remember what the polarity of the circuit is but it will be obvious if this is the case with your unit. Since the main logic power supply is -15V, it is probably a PNP - 2N3906. While I had the machine apart I tried to count all the transistors - I stopped at 600!
The text for the vertical deflection amplifier says "The cycle starts with ZDRV pulsing negative momentarily." This is not the output of the transistor I replaced. It is DC coupled to the AC signal, it's not a differentiator, its output is a square wave. But if the square wave is missing then there probably won't be a pulse on ZDRV.
