So, you think you like Classic hp calculators? Message #1 Posted by Jeremy on 15 Apr 2003, 8:05 p.m.
I have just come to the conclusion that to really appreciate them, you have to at least take one apart. It would also help to have some newer, disposable calculator apart next to it. It was a whole different world back then. They had built something that would have cost $1,500 in today's dollars.
I have just disassembled a 32E, and although it is very nicely made compared to newer calculators, it is not very 'technician-friendly' compared to the Classic series. That snap-together enclosure at the bottom is a terrible idea. Would it really kill them to just use two more screws and make it come apart without any drama? I don't think so. You could argue that the cost would really add up, but I don't think HP was ever shy about transferring that to the consumer, hehe. (Rightfully so.)
The 45 I have had apart though was an absolute dream to work on. The screws came right out. You didn't have to undo anything that couldn't be redone to take it apart. After that, it was pretty intuitive if you just looked at how it went together.
One improvement I will comment on though. The contacts for the keypad on the 32E were pretty much sealed from the outside world, which is a good thing. You could probably spill a Coke right on the keypad and it would still work. They keys would be all sticky and nasty, but since the actual contacts are hermetically sealed from the outside world, everything would be OK.
I do love the features of my 32SII and 48G. The construction is also good. That they cannot be easily taken apart does not make them suffer much, it's just that they're only beautiful on the outside now. They are built once very well, and if anything goes wrong, down the road, tough luck. I think that they have come so far that something is less likely to go wrong on these newer ones than on the older ones. Still, that is only half the beauty. To design something that is rugged, functional, AND reparairable the way the Classic series was designed is truly becoming a lost art.
On that happy note, I hereby urge all owners, (even the non-technically inclined ones) to grab your #1 philips screwdriver and take your classic HP apart. There is an article provided elsewhere on this site that will walk you through it and hopefully prevent too much drama.
-Jeremy
