Re: HP28C beep disable Message #2 Posted by Chris Randle (UK) on 8 Apr 2003, 5:36 p.m., in response to message #1 by madal
Put a 51 on the stack (5 1 ENTER) then SF (for Set Flag) and ENTER. If it's set, there's no beep. If it's cleared (CF) the beep's back.
The soft menu for the flags is TEST. You'll see SF, CF and also FS? which tells you if a flag's set or not (1=Yes, 0=No)
