Re: I hear you, but... Message #6 Posted by Ellis Easley on 9 Apr 2003, 5:47 a.m., in response to message #5 by Jeremy
If it is really grimy, I use a similar technique first using a wide, soft bristle brush loaded with a little soap suds (minimal water). The brush I use is about 3" by 4" with bristles about 1/2" long. I hold the calculator upside down and rub it lightly on the brush in small circles. Then I use the same brush just barely damp a couple times to rinse, keeping the calculator upside down all the time (you can lay it keys down on a towel between scrubbings), then I use the vacuum cleaner to dry it out well.
