Thieves and belt loops... Message #5 Posted by Vieira, Luiz C. (Brazil) on 5 Apr 2003, 1:30 p.m., in response to message #4 by Jeremy
Hi;
I am not sure about others concerns for using or not, but I do not "wear" calculator cases with belt loops anymore because with a small cutting device (knife) they are easily "removed" (stolen) when you're surrounded by people. Also, there are two minor reasons: the belt loop itself getting rough because fo the continuous moviment, and the external exposure, say, all sorts of objects can smash your your calculator if you are transporting it in a case with loop belt, or even whip it out of your belt.
There was a time when only the two minor reasons were significant... and this I miss.
Luiz C. Vieira - Brazil
