Re: I need calc with aglebraic solver ! Message #3 Posted by Ron Ross on 31 Mar 2003, 8:25 a.m., in response to message #1 by mapet
The Hp32sii would fill all of your requirements. That said, it is a very high priced calculator at the moment.
An Hp48G would be your cheapest alternative and also has all of the above. Aside from its size (it is after all a graphics), it would work.
If you COULD give up fractions, an Hp19bii would also work. It actually has the same solver as the 17bii with the addition of trig functions.
All of the above also have units conversions, the 48G has an extensive set of conversions.
