Re: hp-71b installing/removing memory - resulting with hp-il problems Message #5 Posted by Terry Ingram on 30 Mar 2003, 11:04 a.m., in response to message #4 by Raymond Del Tondo (Germany)
No, the hp-il doesn't work with any commands at all. Not even the "reset hpil". I've pulled and re-inserted the module, but the operation is still the same.
I've tried the closed loop test as described on page 211 of the hp-il owner's manual, and do not receive either the screen cursor indicated a good module, or the "self test failed" message indicating service is required. The 71b just remains in a frozen state until I press the ON key several times.
The hp-il module is recognized with the VER$ command, "HPIL:1A".
Unless there is a physical way to reset (short contacts?), I think it may be time for a new hp-il module.
Thanks for your help,
Terry Ingram
