Re: Statistical Bug? Message #9 Posted by Les Bell [Sydney] on 26 Mar 2003, 6:40 p.m., in response to message #3 by Trent Moseley
It happens as you describe on the 41CX, as well, but the reason is simple - it's the data in the Y register. When you get the SDEV result in X, then simply key in 11 and press sigma-, it will have 3.06 in the Y register, which it subtracts from the cumulative stat registers (which will have zero for both sigma Y and sigma(Y^2), from memory).
If you key in a zero before the 11 to be sigma-minussed, or clear the stack, it will work just fine.
Best,
--- Les [http://www.lesbell.com.au]
