Re: Capacitors Message #4 Posted by Malcolm Brooks on 26 Mar 2003, 8:19 p.m., in response to message #2 by David Smith
To David,
Can I have a bit of clarification on which is the capacitor that goes bad for card reading operations for the 67.
In an old message by Tony Duell 12 June 2001 he clearly states the problem cap is a 47uF.
Recent discussion says its a small blue 6.8uF cap.
Is it two different capacitors?
Where exactly are they located?
Would these be the same on the 97 - I have both 67 and 97.
Then there is the 22uF cap - does this not go bad?
Are all tantalum caps the same for our purposes?
Are all tantalum caps polarised?
Any help much appreciated
Thanks Malcolm
