Re: HP 84123 Printer Message #3 Posted by Vieira, Luiz C. (Brazil) on 26 Mar 2003, 7:28 a.m., in response to message #2 by John K. (US)
Hi;
I have an 82143A that's one of the first type and they are very sensitive to the absense of batteries when the AC adapter is connected. There is an IC (probably working in the regulator) that burns when you do it: use an AC adapter without the batteries. Or a battery with bad contact.
Mine became erratic like this.
When mine was repaired I think HP replaced the old IC with a new one, and I did not observe the former behavior so far. But now I take a lot of care when charging batteries or using it.
Not so much of help, I know, but maybe you now have a few more information.
Success.
Luiz C. Vieira - Brazil
