Re: HP-41 card reader "memory lost" Message #3 Posted by Hans Brueggeman [GER] on 27 Mar 2003, 4:25 p.m., in response to message #1 by Michel Beaulieu
michel,
possible cause are worn or dirty battery contacts. try this: open the battery compartment, remove the batteries and clean the battery contacts in the calculator with a cotton swab dipped in pure alcohol (isopropanol for example. DO NOT use anythind else than alcohol). take another swab to dry them. also, clean the contacts of the batteries themselves.
cheers,
hans
