Re: hp 25 simulator Message #3 Posted by Paul Brogger on 25 Mar 2003, 5:41 p.m., in response to message #1 by R Lion
When the page loads, the applet should load with it, though it can take a little time.
Just below the line stating "The applet code is public domain" you should eventually see a graphic of an H-P calculator "R/S" button appear. When the button shows, just "click" the button. I just did it, and it worked fine. (And it IS a cool-looking emulation!)
Good luck -- and post again if that doesn't work. (Though, I'm no HTML/Java debugger, so someone else will have to jump in!)
