RPL programs to replace LSTx command Message #3 Posted by James M. Prange on 19 Mar 2003, 9:51 a.m., in response to message #2 by Vieira, Luiz C. (Brazil)
Some time ago, I posted a 48 series / 49G replacement program for the
"Classic RPN" LSTx command. But in that program, if the
last arguments buffer is empty, then, unlike the classic RPN
LSTx command, it returns nothing to the stack and puts
the real number 0 in the last arguments buffer.
As (I hope) everyone here knows, on a classic RPN calculator (well, at
least those that have a LSTx key), the LAST X register
always exists and always contains one object. Even after a reset of
continuous memory, it contains the number 0 (perhaps arguably 0h in the
case of my 16C). The LSTx command always returns one
object to the stack.
On an RPL calculator, the situation is rather different. It doesn't have
a LAST X register or LSTx command; instead, it has a
last arguments buffer, which contains from 0 through 5 objects, and a
LASTARG (LAST on a 28 series) command which returns from 0 through 5
objects to the stack. Also, it's possible to disable last arguments save
and recovery entirely, for example, by setting system flag -55 on a 48
series or 49G, or by clearing system flag 31 on a 28 series; in this
case the LASTARG (LAST on a 28 series) command errors out.
The following programs should work on any 48 series or 49G calculator,
but for a 28 series, the LASTARG command would have to be changed to
LAST, and, in the second and third programs, the sequence "-55. SF CF"
changed to "31 CF SF".
*Not tested* on a 28 series or with "ROM" revisions other than 1.19-6 on
a 49G. Tested on 48SX ROM version E, 48GX ROM version R, and 49G "ROM"
revision 1.19-6.
Now that I think of it, on a 48 series or 49G, LAST is a synonym for
LASTARG; it compiles to the same thing as LASTARG, but that always
decompiles to LASTARG.
The following programs differ in how they handle the case that the last
arguments buffer is empty. The last arguments buffer will be empty
immediately after a warmstart, and immediately after last arguments is
enabled (-55 CF on a 48 series or 49G, or 31 SF on a 28 series) after
being disabled (-55 SF on a 48 series or 49G, or 31 CF on a 28 series).
All of these programs require that last arguments be enabled (the
default). If last arguments is disabled, then they error out, leaving
the stack and flags unchanged.
The following programs retrieve the level 1 argument of the last command
that took any arguments from the last arguments buffer and return it to
the stack, unless the last arguments buffer is empty. Note that some
commands (CLEAR, DEPTH, STD, MEM, and so on) don't take any arguments,
and leave the last arguments buffer unchanged. Also note that for
commands that evaluate an expression or program, the last arguments are
saved from the evaluated expression or program, not from the original
command. In the case that more than one object is in the last argument
buffer, only the one returned by the program will be in the last
argument buffer when the program finishes.
You can copy the programs (include the "%%HP: T(3)A(R)F(.);" ASCII
header), paste them to a text file, and use the Kermit protocol to
transfer that to your 48 series or 49G.
In the case that you type these in, note that \<< and \>> represent the
opening and closing program delimiters, and \-> represents the right
arrow.
I consider these programs to be simple enough that they don't really
need comments. If you want to see the details of how they work, you can
single-step through them.
I expect that most users, especially those accustomed to classic RPN
calculators, would prefer this first program. If the last arguments
buffer is empty, then the real number 0 is returned to the stack and
also stored in the last arguments buffer.
Checksum on 48 series: # ECA9h
Checksum on 49G: # A414h
Bytes: 69
%%HP: T(3)A(R)F(.);
DEPTH \-> d
LASTARG DEPTH d -
IF
DUP
THEN
DUP2 2. + ROLLD DROPN
END
DUP DROP
Some RPL users might prefer this second program, although it takes more
memory and I suppose that it might be a bit slower. If the last
arguments buffer is empty, then the real number 0 is returned to the
stack and the last arguments buffer is left empty. Note that there is a
very remote possibility that if the user does a warmstart or CANCEL
(ATTN on the 48S series) while the program is running, then the
calculator will be left with last arguments disabled.
Checksum on 48 series: # F5Dh
Checksum on 49G: # D44Fh
Bytes: 94.5
%%HP: T(3)A(R)F(.);
DEPTH \-> d
\<< LASTARG DEPTH d -
IF
DUP
THEN
DUP2 2. + ROLLD DROPN DUP DROP
ELSE
-55. DUP SF CF
END
Some RPL users might even prefer this last program. If the last
arguments buffer is empty, then (unlike the classic RPN
LSTx command) it doesn't return anything to the stack.
This one also leaves the last arguments buffer empty. Like the previous
program, there is a very remote possibility that if the user does a
warmstart or CANCEL (ATTN on the 48S series) while the program is
running, then the calculator will be left with last arguments disabled.
Checksum on 48 series: # D527h
Checksum on 49G: # CD47h
Bytes: 97
%%HP: T(3)A(R)F(.);
DEPTH \-> d
IF
DUP
THEN
ELSE
DROP -55. DUP SF CF
END
Regards, James
