Re: 71b 4K->32K Ram module conversion Message #2 Posted by Ellis Easley on 7 Mar 2003, 1:33 p.m., in response to message #1 by andy
I've been reading the 71B hardware internal design specs on the new Museum CD's and I'll bet that the 4KB RAM module contains one of the four 4KB hybrids that are built in to the 71B. Each of these hybrids is in turn made of four 1KB RAM chips that are designed specifically for the 71B bus. Again, based on my understanding of the spec - not certain knowledge - the 1KB RAM chips are soft configured devices that are daisychained together on the hybrids and the 4KB hybrids are designed so that they can in turn be daisychained, as they are inside the 71B, to make 16KB of RAM which, along with 1.5KB from the display driver chips, adds up to the 17.5KB standard RAM of the 71B. So I think you could daisychain multiple 4KB RAM modules and plug the assembly into one 71B port - not just 4 modules, there should be no logical limit but the CPU's addressing range, although the capacitive loading of paralleled hybrids would set a pretty strict limit. But I don't think you would find a parallel bus with separate address and data and chip select signals to connect a standard memory chip to - in the HP 4K module. The third party memory modules from 32K on up probably do have standard memory chips inside them (again, I'm guessing) and it might be possible to upgrade them, if their designs provide the additional address lines or chip selects required.
