Re: powering the 9114B Disk drive by AC only ... thoughts? Message #4 Posted by Vassilis Prevelakis on 26 Feb 2003, 2:53 p.m., in response to message #2 by Vieira, Luiz C. (Brazil)
Vieira, Luiz C. (Brazil) wrote:
> I believe four 1,600mAH NiMH batteries would do fine, as the original 9114B battery
> pack uses acid-type (gel) batteries.
Here we go again.
If a machine uses lead-acid batteries then the charging ciruit is incompatible with NiMH batteries.
We have been through this before. The only reason that the 9114 battery pack doesn't blow up in your face is that the wimpy HP charger cannot deliver enough current.
If you go to a decent battery shop, you will be able to buy lead-acid batteries in all kinds of sizes. Although Panasonic no longer sells that particular size, there are equivalent batteries from other vendors (e.g. Powersonic), or you can use a slightly smaller battery that will fit in the battery pack.
Now, assuming you do not have an original battery pack (which means that you lack the charging cicruit as well).
In this case, I'd recommend either a bench power supply, or a battery pack (which you can charge separately, i.e. not connected to the 9114).
I wouldn't use a 12V power supply (as sold in e.g. Radio Shack) because some of them are not meant to drive electronics directly. Such power supplies are used to power 12V devices like car radios that have circuitry that stabilizes the power input.
**vp
