John,
If you store the lower limit in register 1 and the upper limit in register 2, then the following code should work for you. Note that the first nine lines are the same as in the manual. The extra lines are added to the end.
For the example you gave, store 0 in register 1 and store 101 in register 2 before calling the program with XEQ A. Each time you hit XEQ A, you will get another random number in the range defined by the numbers in register 1 and register 2.
Also, if this is the only program in memory, you can make sure that it is entered correctly by looking at the checksum, which should be 0xd229. Press SHOW when in program mode to display the checksum.
-eg.
< Original Code in the manual >
01 LBL A
02 RCL 0
03 x
04 9
05 9
06 7
07 =
08 FP
09 STO 0
< New code that returns a random number in the range
defined by register 1 and register 2 >
10 RCL 2
11 -
12 RCL 1
13 =
14 x
15 RCL 0
16 +
17 RCL 1
18 =
19 RTN
