Re: HP 49G Screen Cover Message #2 Posted by Ron Ross on 19 Feb 2003, 8:32 a.m., in response to message #1 by Nick Nicholas
Not from any quick look, but the older lens had a very noticable rainbow effect and would be an ID93### or older. The newer lens cover is definitely available on the ID94###.
Different Faceplate texture and a slight dimple above the Hp logo also indicate a newer Hp49G also (but if you do not have both, you probably do not or cannot determine this).
