Re: HP-11C test Message #4 Posted by Spice_Man on 16 Feb 2003, 3:27 p.m., in response to message #3 by Michel Beaulieu
Yes, that's a successful test!
Another test, the keyboard test, can be done by holding down the "divide" key while turning it on.
Then, press all the keys in sequence starting from the upper left, and go across to the right, then down one row start from left, and across to the right, etc.
(you have to press ENTER key twice for each of the two rows on which it exist)
After the last key is pressed, you'll get the series number displayed (11 in the case of the 11C).
Spicey
