Re: hp85 Tape Gummy Wheel Message #6 Posted by Michael O. Tjebben on 13 Feb 2003, 2:10 p.m., in response to message #5 by andy
I do have some interest in that particular section, Andy.
It doesn't have to be the entire chapter, but just that section.
What info I have is:
Mike,
According to the 85B, service manual (June 1983) the problem may be with the tape speed circuit alignment.
LED DS1 on the capstan motor assembly and phototransistor CR1 on the tape transport assembly. This
would have been disturbed when you remove the capstan motor.
?Without a cartridge inserted, run the Tape Speed Test from the Service ROM. If the message {TAPE
STALLED} appears proceed with step k to reposition the phototransistor?
If you have an o?scope measure at tp-4 (upper tp lower left corner of tape pca) you will need to active the
drive if you do not have the service ROM (I do not have a copy) set the scope as followed:
10usec/div, 2 v/div, ac coupling --you should see 3 cycles of a sine wave the negative portion is limited. The
positive peak should be at least 2.5 v and the negative peak should be a least 2v. Reposition phototransistor
CR1 until the desired waveform is obtained.
If you don?t have a scope then I guess you can try it ?hit or miss?
Another interesting note ?if the customers computer can read tape cartridges that were reordered on the same
computer but cannot read cartridges recorded on another computer the tape head maybe out of alignment.
Align or replace tape drive assembly. Be sure to inform customer that the computer may no longer be able to
read tapes previously recorded on that computer?
Hope this helps
JR
My problem is that I haven't attempted this, because I don't have Service ROM. Hence I'm VERY curious if your information gives me some clues as to how I might "fudge" or "klude" this step.
Thank you, Andy.
-Mike
