This program may work for you Message #3 Posted by gene on 11 Feb 2003, 4:19 p.m., in response to message #2 by Gene
http://www.rskey.org/gene/calcmuseum/162bc2.htm
Requires the 41CX, HP-IL module, and an 82162 HP-IL strip printer.
You will need to get 4 or 5 lines of synthetic programming into the program, but there are bar codes you can print and scan in on that page.
Sorry for the formatting problems at the bottom of the listing. One of those from typing in steps as X<Y? stuff causing the HTML to think it's a like of some sort.
Cheers!
